- 21 Sep 2003
Okay folks, I'm hoping somebody can help with what has been a horrendous day!
Short story, my PC has been crashing a bit of late (only when playing games - it would make a horrible buzzing, lock up and then reboot) and only since I installed a 2070 Super last week and, previously, only when I've tried to overclock. I think it's where the CPU is hitting 100% usage, if that's related (I've googled but it doesn't suggest 100% should cause a crash). That's a secondary issue right now though.
Anyway, today it crashed and then got into a loop of loading Windows but freezing as soon as I tried to open anything (i.e. Chrome) - but now it won't load at all and I get a 'Critical_process_died' error and then a loop of it trying again (and failing). The best I get now is if I let it run for 70+ minutes it'll load to the Windows 10 troubleshooter screen (as automatic repair can't fix it).
Now unfortunately I can't try any of the troubleshooter options because it asks for my account password and, even though I know it's correct (I log on with it all the time, after all), it tells me it is wrong - so I'm well and truly stuck at in a cycle of misery.
I tried downloading the MS Windows 10 Recovery disc using my laptop but when I tried that on my PC (using an external USB HDD) it won't recognise my Windows drive, so I can't even reset my system using that.
My version of Windows was also the free upgrade from 8 to 10, if that makes any difference to anything.
I guess my questions are:
- Why won't it accept my password and is there any way around that?
- Is there any way I'll be able to save my documents and files (either through 'saving' my installation or extracting via other means if the worst came to the worst - i.e. a dock for SSDs that I can then read as an external drive on my laptop)?
- Are there any potential rescue options I can do that I'm not seeing?
I'm keeping everything crossed for some small glimmer of positivity!
