- 1 May 2003
Within the past 24 hours. I noticed that my wireless connection had dropped. The router was turned on downstairs, but I was unable to connect. I typed in the SSID and the passcode, but it kept saying "unable to connect".
I then took the computer downstairs and connected it to the router via the cat5 cable. I have since been able to connect to the internet and when I click on the wireless device. It tells me I am connected. But as soon as I remove the Cat5 cable, I lose my connection.
So far, I have changed the SSID, and the encryption and the passcode. I have even updated all the drivers and even been into the TCPIP setting, to make sure it obtains an IP address automatically But I am quite stumped now
I am using the following hardware
Netgear DG834N Router
Netgear WPN311 Wireless Card
