- 20 Nov 2010
Hi All, thanks in advance for any guidance you can provide. I will of course turn off everyhing at the consumer unit before doing anything.
I recently purchased a zigbee module for use with an on/off switch in my utility room that controls 5 GU10 spotlights. The zigbee module i purchased works with or without a neutral. Here is the product page: Zigbee Switch module [SM308-S] – SAMOTECH - https://www.samotech.co.uk/products/zigbee-switch-sm308-s/
In the back of the existing switch, there are two wires going to L2. I believe one of them goes to the switch in the next room as recently i had a problem(now resolved) with another switch in the house and it stopped the next room from working.
To clarify, the switch i want to change to a zigbee module only controls 5 GU10 spotlights in the room that it's in.
I'm looking for some guidance on how i can remove the phyical switch from the equation completely and wire the zigbee module so that i can have the spotlights controlled by the zigbee module via my phone. Essentially the zigbee module is switched live.
