So i just bought a corsair 540 air,had no need really for it but think its gorgeous case and will allow me to have nice looking build aswell with allowing me to do WC/Sli if i choose.(these wasn't in option in my current case)
So i dont know too much about WC,mostly the pumps/res is where im lost tbh,everything else is easy to figure out lol.
What i want is just do a loop on the CPU,i considered doing both the Cpu/gpu,but i have a habit of changing gpu's quite frequently and the cost of blocks is quite prohibitive for me personally,and 970's dont really need watercooling to begin with.
My main priority is a pump thats quiet,or at least has the ablity to have it speeds lowered.The loops mostly for aesthetics, and to let push my cpu OC further.
I kinda dont wanna spend over £150 (low budget i know,but i just dropped a load on my new case+braided cables ect).I was looking at the techlabs value 240 kit at £100.
Link here http://www.overclockers.co.uk/showproduct.php?prodid=BU-082-TL&groupid=962&catid=1532
Can anyone help figure out if that would be a good starting point for my needs,from what i can tell as a whole bundle its good value,for decent parts.I have no idea about the pump/rez combo tho tbh,or if i could even use it in the vertical ODD bays
Is it possible to spec a decent loop for £150 from individual parts for my needs?
