I've been tinkering a bit with my Aorus Xtreme 3080 since installing it 2 weeks ago. I did a thermal pad swap on it right away with a repaste. Now it mines with better VRAM junction temps, etc. so I thought I should overclock it and see what kind of silicon I pulled.
Ryzen 3800X (no OC, -0.1V offset)
MAG X570 Tomahawk
Aorus Xtreme 3080 Rev. 1
https://www.3dmark.com/3dm/63342871
It's running a custom VF curve with +600 MHz memory, closed case. Stock cooling other than the thermal pads. The curve is basically 2070 MHz at 1v, 2160 MHz at 1.1V.
Now it is pretty easy to tell between air and water cooled cards from the 3DMark scores page. There's usually a 10-30° temperature gap and a few hundred points at least (Port Royal). I may be wrong but I think this is a pretty decent score for someone who doesn't have much experience in OC'ing GPUs.
My question is, knowing my settings, what would you alter to get a higher score? Does RAM/CPU affect the scores? I'd like to get it above 12950 as the highest I've seen anywhere is 12931 on air-cooling.
Thanks for the help as always, this is a great forum.
MAG X570 Tomahawk
