Hi.
I'm doing re-paste into my 3090 Strix and I have a problem with the thickness of the thermal pads for the Vram.
I have Thermalright Odyssey thermal pads (12.8w/mk) of 0.5, 1.0 and 1.5mm.
I haven't made to the gpu yet but the back plate I think the 1.5mm doesn't put enough preasure and I already throw away the foam the vrams had (they were wasted opening the card).
I could stack two thermal pads to make 2.0mm or 2.5mm thickness but I'm not sure if it's a "right" decision.
I can't use the card until I solve this and here it will take 5 days to get 2mm or 3mm thermal pads. So no pc at all.
Anyone knows if 1.5mm will be thick enough or any solution?
