- 21 Aug 2016
Hi all - first post and already asking for help.
Finally saved up for the chance to get a gaming rig sorted and so will be building from scratch. I have set a limited of £700-800 (will be hard to go over this). Only need rig and operating system, would also look to have overclockers build it.
Following the normal advice that you should be going for the best gpu possible for your budget I think a GTX 1060 or RX 480 are the best I can get. With perhaps an i5 processor (not sure on AMD equivalent). I am keen to get into this and will likely upgrade in 18 months or so.
Also, of less importance, but it would be nice to have an SSD in addition to the HDD.
Essentially looking for any advice on the best way to go about this and which areas/dreams I would need to sacrifice to meet the budget and have a solid pc for the next 18 months or more.
Happy to answer any more questions and apologies if I have missed any needed info.
Many thanks in advance!
