Help with 8800gts 320 shader overclock
6 Sep 2007
i have an XFX 8800gts 320, came standard at 500mhz core, 1.6ghz mem and 1188mhz for shader clock speed, i have OC by bios flashing using NiBiTor to speeds of 600mhz for core and 1.9ghz for mem, but i have left my shaderclock as i have never OC this before, if anyone could give me some advice on how much i should overclock it or whether i should or not, i would appreciate it very much,
thank you
thank you for your help.i will try rivatuner and let you know later about the outcome, sulli, at stock speed of 1188mhz for my shader clock how much do you think i could get out of it, from your experience anyway.
hi thanks for the help, i overclocked it from 1188 to 1388 and is stable, with 600 core and 1.8ghz mem. very happy. i cant use ati tool cos vista 64 cant use the ati tool driver cos it isnt digital verified or something like that, thats the pain with vista 64 but can use 3d mark and got a boost in score.
