Help with a bash command
19 Jul 2006
Im trying to get Apache2 and mysql to start when the server is started. Im using openSUSE. And found these instructions on the net
I have logged on as root.
vi /etc/init.d/Mattsstartupscript
Code:
#! /bin/bash
/usr/sbin/rcapache2 start
/usr/sbin/mysql start
echo "Apache and Coldfusion started"
That is as far as I get How do i get the file to save.
I get a error saying "/ect/init.d/mattstartupscript" E212: Cannot open file for writing
Then exit and save it: ctrl+x
chmod 755 /etc/init.d/scriptname
then launch yast2 and goto system->runlevel editor and advanced.
set runlevel 3 or 5 or both for it and launch it.
Hope this worked.
Is that a typo in your command or a typo on the error message? That would explain the error message (/ect doesn't exist).
<pedantic>Ctrl+x doesn't save and exit in vi: you'll need to press <Esc>:wq to do that.</pedantic>
