Help with a build.
15 Feb 2011
Okay so I'm fed up of my low spec laptop and want to build a PC.
I'll be using it mostly for Photoshop, video editing, web designing + whatever I have to do at Uni next year.
Looking for a build excluding the OS, keyboard, mouse, case + monitor.
Got them all already from a family member except the monitor.
Looking to get this one:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-084-LG&groupid=17&catid=949&subcat=
When it's in stock.
Also what would be the differences between choosing AMD and Intel?
Is Intel better because of the hyper threading?
Post away what you think I'd need and then I know how much money I'll need to set aside. The budget is whatever I need to spend really. Nothing over the top as I doubt I'll need like the highest spec PC.
Thanks in advance.
What is your budget to be honest? Come on at least a range, up to £1000? more? less?
For what you described I would say aim at £700 to satisfy your needs, Intel SB 2500k, a decent psu (corsair tx650 or so), 1TB HDD, Motherboard (try to get rev ones) and all the remainder on a GPU, just wait for some more precise recommendations!
Well I was hoping because I don't need a case/OS/Keyboard or Mouse & I'm keeping the monitor on a separate budget it would cost me £400-£600 give or take a £100 if need be.
Was thinking of this:
OcUK Motherboard Bundle - Intel Core i5 2500K & Asus P8P67 Intel P67 Mainboard £286.00
(£238.33) £286.00
(£238.33)
MSI ATI Radeon HD 5850 Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card £149.99
(£124.99) £149.99
(£124.99)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £42.98
(£35.82) £42.98
(£35.82)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £39.98
(£33.32) £39.98
(£33.32)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £11.99
(£9.99) £11.99
(£9.99)
Sub Total : £442.45
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 20.00% VAT : £90.49
Total : £542.94
Or an AMD build which is about £100 less.
