- 27 Mar 2010
- Nr Manchester
I am looking to get an overclock bundle, and i will need a new case to go with it. the problem is that this case will need to fit into a gap in my desk
.. i was after the corsair 400r but its too high to fit, all other measurements are okay.
i was wondering if someone could offer some advice on a case that would fit these measurements (ideally looking for a case that offered some cable management if possible)
width 21cm (only allowing a 1cm airflow gap so maybe a fan on the top)
depth 50cm
height 49cm
the bundle i am looking at to fit this said case is the Super Nova X79 850i Intel Core i7 3820 3.60GHz @ 4.40GHz DDR3 Overclocked Bundle.
just dont want to spend all that money to find it wont fit in the gap i have.
Cheers
Jay
depth 50cm
height 49cm
Cheers
Jay
