I need some help please.
I have these parts and soon plan to build.
Case= Silverstone sg07
CPU = i5 2500
GPU = AMD HD 6950
Motherboard = Gigabyte GA-H67N
I have a few questions. I've not build this yet because i'm still waiting for them ram to arrive. I'm a little concerned about heat. How good is the stock thermal paste and stock cooler on the i5 ?
What cooler would you suggest If i was to replace it? and any other advice on keep the build cool?
The case can handle a 117mm cooler.
http://www.silverstonetek.com/products/p_spec.php?pno=SG07&area=usa
All the parts will be running at stock because I dont overclock.
Thank you.
CPU = i5 2500
GPU = AMD HD 6950
Thank you.
