Help with a HP w19 plz....
18 Oct 2002
Sunny Cheshire
I have just bought the above monitor and have it setup, this replaced my old 19" crt, I play eve online when I try to start eve online after entering my password the monitor goes blank and leaves a message on the screen saying "input unsupported" has anyone else had this? what is the solution, I have tried lower the refresh rates and stuff like that but I don't know what to look for in the game folder, I can't get into the game to alter any settings :confused:
I have that monitor... but your problem is probably because the game is set to run at 1280 x 1204, or whatever you had the game set at on your crt, I've not played eve but on the Widescreengames forum Link the master game list says widescreen is supported natively (in game) so best bet is hook the crt up, go in to the game and lower the res to 800 x 600, then try again with the TFT connected, also if you haven't already, install the monitor drivers off the HP website.
hth, Sherwood
