Hey,
I'm looking at building a fairly cheap HTPC because I don't want to keep using my laptop to do it. I've done a bit of research and want to use the Asus E35M1-I DELUXE motherboard due to integrated CPU and gfx, also it's got wifi built in which is a plus. I already own a 2TB Seagate HDD so thinking of buying a 60GB SSD for the OS and for extra silence!
I'm wanting to put it all in a Silverstone Milo ML03B case. Just need a bit of advice whether this will work alright? If it will, what PSU and RAM do you recommend?
The mobo spec is a little confusing, one says it supports single channel DDR3 ram and another states dual channel. I've read a couple of people have had trouble getting a second stick of ram to be recognised so want to make sure I get the correct stuff!
Then finally just need a psu, I'm guessing cheap and silent doesn't really exist?
Will just stick a DVD rom in there, not too fussed about blu-ray at the minute.
.Will just stick a DVD rom in there, not too fussed about blu-ray at the minute.
