Help with a lens please
11 Jun 2004
Middlesex, London
Hi all,
What I would really like is a Canon L Series (24-70mm) F2.8 - But this is what I cannot afford :(
What I'd like help on - is finding a good alternative Sigma or Tamron?
Thanks
The Tamron 17-50 on a cropped sensor camera is apparently as good as it gets for an "on the budget" sharp lens for indoors and out.
Are we talking about this one?
If I could'nt afford Canon then I always went for Sigma. Seen some nasty Tamron in my time but in saying that I cant comment on Tamron stuff as it is now.
Loved my Sigma 18-50 2.8.
I hated mine.
http://www.talkphotography.co.uk/forums/showthread.php?t=81694&highlight=sigma
ignore the guy call d_pipa, he doesn't know what he is talking about, with comments like using higher F-stops and hand held to get a more steady shot......
Unlucky there mate. Mine was 2nd hand and is sharp. Usable at all apertures and really sharp IMO from f/3.5 at all lengths.
Love it tbh, the contrast is great, it's well built and balances lovely with a battery grip on a 400d. Switching to MF can be a bit fiddly as you need to push the switch and also click the ring forward/back.
Lens hood is good but getting the cap off can be fiddly with the hood on. I have the nack now :D
I wanted it to be good, trust me i did, i even ordered a Hoya Pro1 UV filter too, but too alte to cancel and now I have a new 82mm filter that i have no lens to put onto !
I am getting the Canon one, it costs more but i don't trust sigma anymore, it may be a bad batch but I am not getting it again, the shop might think i am taking the P.
I have a Sigma 24-60 f2.8 and it's a nice lens, paid £105 used. Sigma quality control is rubbish but if you get a good one it's worth it for the savings you make. Buying used is probably the best way to make sure you get a good one (assuming it's from a reputable seller).
I posted this in another thread a little while ago.
