Hi there
I want to do an MILD OC on my I7 860 which currently runs @ 2.8ghz
I read somewhere that you have to double a certain ratio in RAM but i happen to have a bit faster RAM than the ussual i think so i dont really want to OC my ram :
Corsair DDR3-2000 Kit 2x4GB XMS3
2000 MHz CAS 9
1.65 V
I have a PD55-GD65 MSI Mobo and i use a Sythe Muggen 2 RevB cooler.
I tried OC genie but i dont like it it pushed it to 3.6/3.8 ghz but not stable, i got a bsod with it on. Also the system seems to constantly run at 100% which i dont like, if there would be things to fix this in combination with OC genie i might consider trying that again.
I dont want to go really far with the OC, and i read that an simple OC should be very easy on an I7. I would already be happy if i could push it to arround 3.4GHZ for example, that shoudnt be too hard right ? I get very low temperatures 25C idle and 40C stressed atm.
What settings would i need to use to archieve this ? Do i still need to OC my ram along with it ?
2000 MHz CAS 9
1.65 V
