Help with a mod design...
13 Sep 2009
Maidstone, Kent
So, I would like to mod the In-Win Ironclad case after being impressed with the quality of it. Simply, I would like to add a large side window. I realise this will be easy by removing the side mesh, but I would like to see a bit more. I do like the mesh on the side, but I like to clearly see what is inside, do you have any ideas on maybe incorporating the mesh into the new panel? And any ideas on how to maintain fan space on the panel. I am very undecided! If you would just go over the picture in MS paint or explain a design it would be greatly appreciated!
Some ideas on alternative shapes of the window would be appreciated, and I would like to make it bigger, showing the drive bays, although this would involve a bit of cutting.
Please bear in mind this will be my first mod though! I will be spraying a few bits on the inside orange and adding some xigmatek fans as well.
