Help with a new system?
24 Feb 2013
I've had a Pentium 4 @ 3.02GHz with 1GB of RAM for about the past 10 years now. It's handled pretty much everything I've wanted it to but now it's really showing it's age and I need something new.
My budget is £400-450 and I'd want this system for everyday browsing (multiple tabs/windows), some light Photoshopping (working with fairly small files) and general use. I don't play PC games at all as I have a console for that (sorry to the PC gamer enthusiasts! :P)
I also watch a ton of TV shows and movies daily, all at 720p/1080p but using DXVA, I let my current XFX Radeon 4650 handle the load so the CPU is kept my CPU entirely free (doesn't push past 20% usage while even the card's usage only bounces between 15-25% even on 20-40GB files).
I don't need a crazy good PC as you can tell because I don't do anything too intensive, but I want a solid system nonetheless. Can anyone help me out in that price range?
I don't require a monitor as I've got a fairly new one. Mouse/keyboard I'm OK with but may buy new later on. Sound card/speaker system also not necessary as I adore my current Santa Cruz Turtle Beach/Altec Lansing combo -- it'd be ideal if the new motherboard had a slot for my Santa Cruz PCI sound card.
Thanks in advance!
Hello and welcome to the forum.
Do you have a sata hdd and odd( if IDE, they will obviously need to be replaced), Psu, case or OS you can reuse? This would free up money that can be spent in other areas.
My apologies for not being more thorough in the first post I made - didn't think it through well enough at the time unfortunately.
My current primary HDD is an IDE one and I do also have a 1TB Samsung SpinPoint SATA drive installed in my current system but it's filled with TV shows/movies/backups so I would require a new one as my main drive for this new system (and I'd install the SpinPoint into it and continue to use as a storage drive like I have done up until now).
The new primary drive doesn't have to be big, even a SATA drive with 150-300GB capacity would be fine for me. I will need an ODD/PSU/case! OS is already covered.
Thanks again in advance.
