Help with a note generator
28 Jun 2006
Hello all :)
I currently have something in Excel with set options created on it, I select what I want, write the text I need and it puts it all together at the bottom, so I can copy it over to where it needs to be in the correct format.
The problem - I am very bad with excel and it needs to be updated.
Solution (hopefully) - I would like to make something web based instead. I was thinking options coming from drop down menus going down the side, a box to write a note in and then a generate button at the bottom to output the whole note (with the options selected from the drop downs) in the correct format.
It will be a little project I want to try. Any good websites to read up on? Suggestions on software to use? Anything similar you know of already made that I could edit for my needs?
Any help would be greatly appreciated. Thank you :)
I was already a software developer with other languages so it was easy for me to learn HTML, CSS, PHP, etc. But I would recommend taking a look at MMTUTS youtube channel on those languages.
