- 10 Jan 2009
Ok so a few months ago i bought a Titan Accelerator system off OC and worked fine for a month or two. Recently though ive been having problems, such as;
-Control Panel outline flickering up for a mili second then disappearing and i am not able to view or change settings through my control panel.
-Teamspeak problems in which i get an error message about sound drivers and even when updated the microphone will not work (messed about with all settings etc. just not working)
-Sometimes unable to install programmes when asking for admin permission, i accept it and still doesnt allow it to happen.
Now its very annoying and ive been putting up with it for a while, i read somewhwere about the conflagger virus doing the control pannel stuff, but gave a scan and nothing was found.
By the way ive explained things you can probably see im no computer expert so doing things like reformatting and reinstalling all the drivers, Vista 64 and all that jazz may be a bit of a trouble to me..
What do you guys suggest.. i reformat the PC and start from scratch.. or as its under waranty send it into OC for the fix..
Thanks Evil
Thanks Evil
