- 19 Mar 2021
Hi, |I want to do something different with my tower 900 case. If you can imagine the case or look at this image ( 3rd down )
www.thermaltake.com
I want to fit a 240 rad on both sides of the center stand but it is hard to find a vertical mount that is the same width as a radiator so I can drill it into the case base. Does anyone know of such a vertical stand that is a perfect fit to a 240 rad?. There is no extra space it is literally the same space as a 240. thanks
The Tower 900
Design Collaboration by Thermaltake and Watermod France. The Tower 900 Tempered Glass E-ATX panoramic viewing gaming computer case .
