Hi all-
work supplied a 'new'
laptop but wouldnt stretch to a dock for working from home... so thought Id pick one up. HP ones are expensive!
so picked up a
Targus from ebay - didnt notice it didnt have cables! but thought would try anyways once I got it.
I bought a Targus Had a 90 watt laptop supply that connects to the dock - this too was cheap so thought that would work (think the original is 100watt)
Have plugged in USB C to laptop USB C - charges laptop.
Plugging in 2 x HDMI gets no display to the monitors.
*Am I missing a special connector to go from Dock to Laptop that enables the power to the displays?
* Is the USB C to USBC cable Im using only supplying power but no display? how can you tell ?
(think it was from my Quest 2) - I dont have any other USBc to USBc cable handy.
Am I missing something else.
Thanks in advance.
so picked up a
Thanks in advance.
