Help with a versatile PC build
28 Nov 2019
Hello, I was originally going to post a parts list but I’m suffering from information overload as I haven’t built a PC from scratch for a long, long time and my experience is about 10 years out of date.
I was wondering if you could help? I’m looking to build a versatile PC for a number of interests.
My use cases are:
  • Running virtual machines
  • Application development (inc within VMs)
  • Graphics: gaming, video editing etc.
  • Option for VR in the future (I’m thinking SLI at some point, maybe)
  • Flexible on the case as long as its not too over the top
  • Looking for a monitor that allows the full potential of the graphics card
Approx. budget £2,000 - £3,000
Shortlist parts:
11GB EVGA GeForce RTX 2080 Ti or Black edition
(it’s a very short, short list)
I appreciate any and all help, I’m starting to lose it on this one
There's an argument for a 12 core/24 thread CPU given all the different usage and types of usage (and your considerable budget).
Looks like you might need/would benefit from quite a bit of storage. Those NVME M.2 SSDs are fast and not too far off the price of regular SATA SSDs now.
For motherboard a cheaper one around £200-ish would do but those just have 2 x M.2 slots so specced a good option with 3. Really when it comes to 3 x M.2s and well-built boards it (arguably) now comes down to the MSI X570 Unify or the more expensive Gigabyte X570 Aorus Master, so take your pick, or sacrifice a third M.2 slot for something cheaper like the Gigabyte X570 Aorus Elite.
You may or may not benefit from 64GB RAM. I don't want to overspec there and would suggest starting off with 32GB. It will likely be plenty. If you find scenarios using absolutely all the 32GB then you can add two more sticks in future. That Crucial 2x16GB 3200MHz kit is currently very cheap and it overclocks to 3600MHz very well (Micron E-Die). The red kit is currently the cheapest (there's white and also grey).
I've specced a quality 1000W power supply because you mentioned SLI, however these days SLI (NVLink now) is going out the window in terms of widespread support for it. To quote from a review website (Tweaktown):
Don't expect all games to have great scaling (especially at 1080p)
Don't expect all games to work with multiple graphics cards
Synthetic tests kick ass to show you the CAPABILITIES, but do not translate into real-world gaming
4K in the right game, makes GREAT use of two RTX 2080 SUPER cards
Read more: https://www.tweaktown.com/articles/9070/nvidia-geforce-rtx-2080-super-nvlink-benchmarked/index.html
So you could scale down to a 650W or 750W if you prefer.
The 2080Ti doesn't make much sense for the money. Would suggest capping GPU choice at a 2080 Super. Next year there'll be faster cards than 2080Ti, and the year after that, and so on. It just doesn't offer enough improvement.
No monitor yet, thinking best to focus on discussing the tower with the components first, then we can get to talking about the monitor to cut down on information overload. :)
Here's a similar spec with all the parts from OcUK, with the Aorus Master motherboard and a 750W PSU instead:
My basket at Overclockers UK:
Total: £2,302.57 (includes shipping: £14.70)
Total: £2,931.45 (includes shipping: £19.62)
single most powerful card you can afford- then you think about SLi afterwards . glad to see support for **70 series of cards removed but think 80 series needs to be pulled and only for Ti/Titan models.
Gaming OC has 4 yr warranty . Handy on rtx 2070 + were your paying £400+ for a card.
dont need the wifi then drop to the Aorus Pro- UK RMA on gigabyte Boards
few more pennies but 165hz 1440p monitor over the 144hz/1440p version above
https://www.overclockers.co.uk/giga...tible-led-backlit-gaming-monit-mo-004-gi.html
more screen area, again increasing the price, 32" from 27"
https://www.overclockers.co.uk/lg-3...65hz-gaming-widescreen-monitor-mo-14p-lg.html
Thanks for the replies.
Based on the above I’m leaning away from the TI & SLI and onto a single:
https://www.overclockers.co.uk/msi-...ddr6-pci-express-graphics-card-gx-35z-ms.html
Do you think this makes sense? Or is it worth not skimping?
With that in mind, would you recommend a change in MOBO to a single GPU socket? Based on Danny75’s response it seems like keeping the GPU up to date will make more sense than getting 2x in SLI?
I really appreciate this help & recommendations.
I have 2080 no super and runs fine with 1440p/144hz gaming . so does RX 5700 XT for £375 quid. Naturally not as powerful as 2080/2080s but £230 cheaper .
https://www.overclockers.co.uk/giga...ddr6-pci-express-graphics-card-gx-1b9-gi.html
that MSI is on a good deal. card would run a little warm and hot as more cores and faster GDDR6 ram but good price.
depends on what your doing. Ti is the best card you can get, but saving with 2080s/2070s/rx5700xt can be put to 16 core ryzen- which might be better for VM ? and how many VMs do you run?
If your pushing the latest VR headsets then extra horse power of the Ti should keep highest frames/hz rate to combat sickness and keep immersion high as possible
mobo is the same above as listed- Pro/Edge
Nvidia will release new cards first half 2020.
(Arguably) best cheaper non-SLI X570 board (2 x M.2 slots):
Total: £220.49 (includes shipping: £10.50)
If you get 2 x NVME SSDs you would benefit from a little heatsink for one of them as the board only has a thermal guard on one of the slots.
Total: £28.08 (includes shipping: £8.70)
@Danny75 heard they are also doing a trade in scheme, kidney for half of the cards payment :D
seems they have been relentless with product range and clawed back high marketshare . Really hope AMD just drops an Infinity fabric dual 5700xt out of no where if 5900 is taking a while to hit the market
only problem with Ryzen... need a GPU of some forum if waiting for next years GPUs :(
another thing i wish for, AMD releasing CPUs with basic iGPU on higher end ryzens. even if one CU on it :(
lol they have indeed.
Yes, and I think he will game rightaway but the VR is for the future so it's an option to not overspend on GPU just now (+£400 for maybe 15% increase after a bit of undervolting and/or overclocking). In fact, an RX 5700 XT or 2070 Super could be an option as well, enough to drive 1440p 144Hz at close to high settings, mostly, and then splash on a newer card when he goes all out on VR. Normally the cheaper the card, the less resell value it loses. Could come out to paying £100-150 or thereabouts for using it over 6 months, for example.
My current shopping list is below. I’ve got a couple of questions if you don’t mind:
1. Am I right in thinking I need a separate WIFI card for the MOBO? If yes do you have anything to recommend? Note: I’ll likely upgrade to Fibre Optic next year.
2. Is there a less showy monitor you would recommend? I’m looking for full potential but something low key.
3. You’ll see I’m still on the GPU fence but I’m thinking single GPU only based on what you’ve mentioned
MOBO
https://www.overclockers.co.uk/giga...4-x570-chipset-atx-motherboard-mb-57w-gi.html
GPU?
GPU?
https://www.overclockers.co.uk/giga...ddr6-pci-express-graphics-card-gx-1a0-gi.html
RAM
https://www.overclockers.co.uk/cruc...b-kit-2-x-16gb-ddr4-3200-udimm-my-20d-cr.html
Processor
https://www.overclockers.co.uk/amd-....6ghz-socket-am4-processor-oem-cp-3bp-am.html
Cooling
https://www.overclockers.co.uk/be-quiet-dark-rock-pro-4-cpu-cooler-hs-01c-bq.html
PSU
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020195-uk-ca-24s-cs.html
SSD
https://www.overclockers.co.uk/cors...-state-drive-cssd-f1920gbmp510-hd-066-cs.html
SSD - Heat Sync
https://www.overclockers.co.uk/ek-water-blocks-ek-m.2-nvme-heatsink-black-hs-001-ek.html
Case
https://www.overclockers.co.uk/be-q...ower-case-black-tempered-glass-ca-13s-bq.html
Anything else to consider before I take the plunge?
I really appreciate this!
If only getting a single NVME drive, dump the heatsink (mobo has one) and get an extra 140mm fan for that case. You can move the rear fan to the front so you have two which are the same there and the new third to the rear.
Sticking with BeQuiet and same max RPM as the two stock case fans:
Total: £29.69 (includes shipping: £8.70)​
There are cheaper ones though.
If you need Wifi the Asus TUF is also a good board:
Total: £195.49 (includes shipping: £10.50)​
Will have a look at monitors. Some of the superwide 3440x1440 monitors can look more classy and be more useful for productivity. Are you settled on 2560x1440?
Hmm they're all pretty flashy in some way. This is the one I had in mind when speccing the £2,170 build because you can land it for £850 to max out the 3K budget:
Dell Alienware AW3418Dw
Came across this one this morning and am now considering it for myself. It's being raved about, however none of the monitor reviewers I'm familiar with or respect have touched it yet:
Total: £461.09 (includes shipping: £11.10)​
Quite fancy trying their simulated HDRi feature for watching movies. Real HDR seems to require way too much brightness for my eyes. For editing, which I rarely do, it's got a surprisingly good 95% DCI-P3 colour gamut for a gaming monitor, so it seems quite versatile. Says 10-bit but often they are 8-bit + dithering so will see if anyone who knows their monitor stuff can confirm. Doesn't look flashy either, possibly a diamond in the rough, this one.
Nice. The paste the BeQuiet cooler comes with may or may not be better than that Akasa paste FWIW. I would just use the BeQuiet (I think it's one application in quantity) and keep the Akasa for a rainy day.
Cheers for that. I was wondering if it was included but didn’t see it in the description.
I'm looking forward to this build!
