Help with a XSPC D5 Photon 270 Reservoir/Pump Combo
13 Jun 2007
Dorset
I have secured the reservoir plate using the enclosed screws but the glass tube rotates/Swivels. Is this normal or is there a way to stop the tube moving?
Thanks.
It will still be able to rotate when bolted down as nothing holds the res to the mounts other than friction.
Mine doesn't spin freely though, you have to use a fair bit of force to turn it (well, you can't turn it at all now it's plumbed in with hard-line tubing).
Does rotate for me as well....not exactly freely, but it's still relatively easy to move.
Actually kind of handy if needing to angle the unit slightly in order to access the speed dial.
Thanks for the confirmation...
