Help with Access/SQL
2 Aug 2004
Buckinghamshire
So I'm a complete and utter novice when it comes to Access, and I'm having trouble trying to setup a crude table correctly in order to get the fields in a PivotTable friendly layout.
I need the layout as I'm going to drive a PivotTable from the access database and currently, each fact is a separate field which means I can't utilize a slicer to switch between viewing different facts.
What I want to try and do is change the layout from how it is in the top, to how is should look at the bottom:
https://i.~ibb.co~/9tw0RN0/Picture1.jpg
upload images
Any ideas? There's some SQL using Union All that I've Googled but it just errors out on me.
From what I can make out on my phone screen you're in effect looking to pivot the data in your SQL already?
It's a pain in the backside to get your head around initially but the pivot command should do what you need.
Been there and realised that its far superior to just design the DB well then using a Power Query in Excel to do tons of things very quickly that take ages to hack and waste time in Access.
This one is a ball ache but I have managed it in the past. Something I recall (which is degrading rapidly these days as I get older) is you get the query broken down into two SELECT statements. Split the statements with a UNION , e.g.
Code:
SELECT blah blah
UNION
SELECT more detail
ORDER BY blah;
then end with your conditions. To fastrack past the errors check each SELECT works on its own before trying to join them.
