- 19 May 2013
- Ireland
Silly question so apologies in advanced but any help appreciated.
Just built a small gaming PC for the kids consisting of a Phanteks Enthoo Pro M / Gigabyte GA-H110M-S2HP Micro ATX mobo / EVGA 430 W.
This issue I am having resides around cooling. The motherboard I got them only has 1 additional Fan Header on it (excluding the CPU header).
I had bought the Phanteks PWM Fan Hub from here but when I try to power the fans through it whilst it's connected to a SATA power connection, doesn't work.
At the moment, have 2 140mm fans in the case, both being powered by that 1 motherboard fan port using a splitter cable.
Have a number of 120mm Noctua Redux fans I want to use but not sure how to proceed ?
The Fan Hub worked fin on my Z170 when it was being powered directly from the motherboard ?
Am I doing something wrong ?
Final note, the Sata connection I was attempting to use is also powering my Boot SSD Drive.
Thank you.
Thank you.
