Help with an odd fan/motherboard problem
27 Apr 2006
Essex
Hey guys - I've just encountered a problem that I don't really understand. I have a Gigabyte G-Power Pro cooler on my AW8 board, and I'm using the fan controller that came with the cooler. Last night my PC woke me up with lots of beeping and it seemed that the fan on the cooler had stopped, so I shut it down, fell asleep again and then came back to it this morning. Now this morning the cooler was working fine until about 20 minutes ago when the same thing happened, so I restarted without the fan controller connected to the cooler (it then runs at max speed), but for some reason without the controller connected the motherboard won't find my master HD. If I plug the controller back in then it will detect it without any probs. So I guess the question I'm asking is: is it most likely that the cooler, PSU or board is bad if the cooler just randomly stops working, and the second question is why does one of my hard drives become invisible when I unplug the fan controller?
Thanks!
Edit: manual for the cooler is here if you want to see how the CPU fan controller fits in.
2nd Edit: OcUK product page link changed
Just going to bump this once because I realise its a weird query. I guess the question that might be able to be answered more conclusively is why my board won't detect my 2nd HD when I unplug the CPU cooler fan controller?
It's strange but I cannot reproduce the problem now, even though I did it several times over the course of the day yesterday. Voltages are rock solid and I can now unplug the controller without losing the HD. I'll keep my fingers crossed that the PC was just having a weird moment ... Thanks for the reply!
