I've been sorting out my loop layout for my project here: http://forums.overclockers.co.uk/showthread.php?t=18467916
In order to make it work I'll need a right angled fitting, I've got two from a previous build but they leaked so I ordered a bitspower one and it seems like it's going to do exactly the same thing which makes my believe they just aren't compatible with my EK barbs.
The problem seems to be that no matter how tight I try to make them the o ring remains uncompressed...
If I was to add a second o ring would that create a tight enough seal? or is there another way to remedy this?
Thanks
Thanks
