- 17 May 2025
- United Kingdom
I'm removing the 6 fans that came with my case, they are molex and daisy chained so I have no control over the speeds hence it's noisy and after using the computer for an hour I look forward to switching it off to get some peace!
I would like to replace them with Arctic P12 fans so that I can control them with the motherboard and make things a little quieter, these seem triffic value at £6 and have an insane 10 year warranty.
Problem is, my motherboard (msi b850 gaming wifi plus) only has 4 sys fan connectors.
The motherboard manual says the max current for each of these fans is 1a.
The arctic website says the P12 fans are 0.1 A
But the overclockers site says: 0.08 A
So I'm just wondering if i would be able to safely connect 2 fans to 1 motherboard header? (wondered if 0.1a was a mistake for 1a)
I've been looking at the Arctic Freezer AM5 twin fan CPU cooler to go with it but am worried that it may not be very sturdy as it only has 2 securing screws
