Help with asp here please
26 Sep 2003
essex
I'm new to asp and need some help...
I'm trying to allow a user to enter text into a text box (which I've done). I then want to read through a database table (access db) and use this data to do some text matching against the text box.
I just can't work out what to use. In VB I would have loaded the table into a recordset and read round that. Can I do this with asp ?
'asp' is vbscript, so it's pretty much the same thing.
Code:
Set RS= cn.Execute("select info from table")
Do While Not RSS.eof
	Response.Write RS("info")
RS.MoveNext
Loop
Code:
RS.MoveNext
Loop
Thanks,
I'll give that a go. :)
I suppose I was getting a little confused with the 'AccessDataSource Control' and how I would use that to do this, although I don't want to display the table and that's all this seems to do.
