I'm getting fed up with modifying the voltage, in the Asus tool, then firing up Rivatuner and setting clocks (so as to disable Powerplay) - and then the fact that power play is disabled till next boot - its all a bit of a faff
once I'm happy with my stable clocks (further testing is needed but it will be something like 970/1100 - will do higher clocks than 970 but needs a big voltage bump)
whats the best process please ?
do I use RBE ? then do I download my own currnet bios ? or just download one of the already downloaded ones off the web ?
then - is it just clock info 03 and 09 I change ? and what about memory frequency - which clock infos do I change so as to avoid the "flickering" problem you get when normally overclocking the memory with powerplay still enabled
last one - when you change clock info 03 and 09 - can you put in any voltage in there ? or does it have to be one exactly from a lookup table ? ie like when you set the volts in Asus tool - you may select say 1.35V but actually it sets 1.345 (made up numbers but you get my question)
thanks very much for any help
cheers
cheers
