Help with Boot.ini
28 Jun 2006
Hello all :)
I have windows xp on a raid 0 set-up. I have a separate hard drive and last night I installed windows xp on it. When I restarted the computer, when booting, I didn't have the option to boot into the newly installed windows xp, only my usual options: "windows xp", "windows setup" (been there for a while from messing about before, would be good to get rid of that as well please) and "windows default" from installing the amd dual core drivers.
Here is what it currently looks like:
[Boot Loader]
Timeout=5
Default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
C:\$WIN_NT$.~BT\BOOTSECT.DAT="Microsoft Windows XP Professional Setup"
Can someone help me add a line to my boot.ini so I can boot into my newly installed windows xp and remove the line for the windows xp setup?
Thank you :)
I'm not certain but delete:
"C:\$WIN_NT$.~BT\BOOTSECT.DAT="Microsoft Windows XP Professional Setup"
Think that should make it boot straight into windows.
