Hi,
I am a first time PC builder, I have just put together all the components and am having issues installing Windows. I downloaded Windows 10 from Microsoft and created a bootable USB using Unetbootin on my Mac (I made sure for format the drive as FAT32 with Terminal). I managed to change the boot order so the USB was first but I get stuck at "Verifying DMI Pool Data...".
When I select the USB using the F12 Boot Menu it says "Boot Disk Error, Insert Disk and Press Enter"
Please can anyone help with either issue. I have checked and rechecked all cable connections but now I am really stuck. The USB and Hard Drive are all showing up on the BIOS menu as well.
Thanks in advance! Specs below...
M/B - Gigabyte 78LMT-USB3
CPU - AMD FX6300
RAM - 8GB Corsair Balistix
HDD - Western Digital WD3200AAJS 320GB
Power - Corsair CX430
CPU - AMD FX6300
