Help with braid size
27 Nov 2008
UK
Has anyone got a guide for which braid to use for what something along the lines of:
1/8 Braid = Fan Cables, Single PSU cables
ect ect
Also maybe what heatshrink to use would be good.
Cheers
Ulti
heres what i used...
single cables braidied in 4mm Black Cable Braid using Black 2:1 Heatshrink (For 3-4mm Braiding)
i used Black 2:1 Heatshrink (For 10mm Braiding) with 10mm Black Cable Braid for my SATA cables
Like said, Heatshrink 12mm shrinks to 6mm, 6mm shrinks to 3mm etc. The most common is 2:1, you can get 3:1 but its considerably more expensive!
I used 3mm braid for my individual wires, but I dont think theres much difference between that and the 4mm.
As for SATA cables I used 8mm and it was a nice snug fit, I'd of thought 10mm would be a bit... "saggy" haha? Also used some 8mm stuff for the CPU ATX power cables, could fit 4 wires in it easily :)
