- 23 Nov 2011
Ok, I have not build a computer in about a decade so any help you can provide would be great!!
Just like some people, bought BF3 and realized my PC is crap
Currently using (Don't laugh
Intel (R) Xeon (R) 5130 @ 2.4GHz (x2)
Ram: 4GB (2x2GB)
Nvidia GTX 560 DC11 TOP/2DI
Rest is random crap (don't have access to my comp atm)
I live under the impression if its not broken don't fix it.... well this is crap enough to be classed as broken.
Thinking about:
CPU: Intel CPU Core i7 2700K Quad Core Processor - 3.5GHz OEM or i5, I have seen some people say i5 is better for gaming?! Either way the i7 I mentioned would cost me £185 if you recommend i5 which one?
GPU: Will keep what I have, will probably get another of the same and SLi, that would be another £115
Motherboard... I am clueless!! Anything you can recommend would be great! Of course without the motherboard I cannot really place which RAM/HDD etc to get, so if you have suggestions i would very much appreciate it
Also looking to get the case, PSU, liquid cooling etc...
The prices above are cheap, but I have the perks of being about to buy through work at a decent discount
Many thanks
Ram: 4GB (2x2GB)
Thinking about:
Many thanks
