I was wondering if you would be able to help me, I'm currently looking to rebuild my rig as its quite old now and virtually falling apart! I can build it but I dont have a clue which components are best etc and hopefully you could help me out. I have around 700 to spend can be more if its worth it.
If you could give me some advice on what to get it would be great, if possible including the NZXT Phantom case and I already have a Corsair HX 520W power supply so hopefully wont need to get another one
Thanks for your help in advance
