Help with build
1 Mar 2009
Hi all,
I'm after a bit of help with a new build. I think my systems about ready for an overhaul from the ground up.
My current spec is
XFX 4870
Core 2 Duo 2.6 OC 3Ghz
4 GB Ram
Firstly do you think its ready? Or do I wait for the next ATI GPU?
I have about £1100 to play with. Main purpose will be games (BF3, Deus Ex, Skyrim Web design and Photoshop, photo, video storage)
Please could you recommend:
CPU
Mobo (Preferably Gigabyte - never had any issues)
8GB Ram
Graphics (Preferably XFX - never had any issues)
PSU
Cooling
Hard drive - (Need 1TB of storage)
Case - (Like the look of Fractal Design Define R3 Midi or Corsair Graphite 600T Midi
Maybe raid 1
Many Thanks
Go for the 600T (theres a project log featuring one in Project Logs) as it is good for Cable Management.
Go for an i5 2500k as people keep overclocking them to around 4.5 GHz and are still going.
Lots of people seem to be using the Gelid Tranquillo in their builds and get good temps especially for only 25£
You can start from this and change some of the components. I have added R3 as it is a lot cheeper than 600T and also 750W PSU so you can add second 570 later on.
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card £254.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard Asrock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155) DDR3 Motherboard £169.98
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive £94.99
Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-750TXV2UK) Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-750TXV2UK) £92.99
Fractal Design Define R3 Midi Tower Case - Black Pearl Fractal Design Define R3 Midi Tower Case - Black Pearl £69.98
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) £49.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £44.99
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £25.99
Total : £990.40
