Help with building a SFF PC
23 Dec 2014
I'm going to purchase a small gaming PC. I have a few questions about compatibility. I'm basing the build around the 970 GTX and 4790K.
Here is the build I was thinking.
CPU - http://www.overclockers.co.uk/showproduct.php?prodid=CP-539-IN
GPU - http://www.overclockers.co.uk/showproduct.php?prodid=GX-153-GI
RAM - http://www.overclockers.co.uk/showproduct.php?prodid=MY-381-CS
MB - http://www.overclockers.co.uk/showproduct.php?prodid=MB-620-AS
CASE - http://www.overclockers.co.uk/showproduct.php?prodid=CA-142-BX
PSU - http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-SF
SSD - http://www.overclockers.co.uk/showproduct.php?prodid=HD-051-KS
HDD - http://www.overclockers.co.uk/showproduct.php?prodid=HD-257-SE
I travel home a lot via train and also attend LAN events which means I'm going to be lugging it around everywhere so it is important that I can either carry it or fit it in a medium sized suitcase.
Can the 970 GTX fit in that case? Any suggestions on changes to the changes to the hardware?
Cheers
Some reviews have stated it is a tight fit with the PSU orientated with the fan facing outward it can drop the clearance to 290mm or even 250mm if the lower rail is required.
However the GPU should be fine:
Standard Graphics Card Dimensions:
Length 215mm
Height 111mm
Width 2-slot
This is taken from the Inno3D website:
Inno3D GeForce GTX 970 OC
