Hi all,
I'm looking to buy a new PC but a bit unsure of what to go for. My old PC is years old, i built it when i was well into games (about 4 years ago). Slowly bits failed, like the PSU first, and then stick after stick of RAM(only got 512mb now), and the gfx card. Another PSU has recently gone, the gfx card is an x1800XT.
Pretty embarresing!
The components are so old now its not worth replacing the PSU to get it up and running again, im just going to get a new system which hopefully wont drive me mad every time i turn it on.
I'm not really into games anymore, but would like the ability to play every now and again, so dont need anything brilliant there. The PC would be used mainly for office type things, browsing the web and programming applications.
I'd probably dual boot linux, and have a version of windows installed, XP or windows 7.
I'd prefer to buy pre-built, but can build my own if it works out a lot cheaper.
What system would you recommend for me?
Is it worth using my X1800XT to get me by until dx11 cards are the norm and prices drop? (on dx10.1 cards too)
//EDIT//
My budget is £400.
What about this PC. I could use my old gfx card until i want to upgrade? How futureproof do you think the machine is?
Thanks for any advice,
Gareth
Pretty embarresing!
//EDIT//
My budget is £400.
Gareth
