Help with C I/O Copy Data
9 Dec 2006
@ManCave
Code below,
basically if you run it it asks:
Please Enter The Full Path To Your File You Want To Copy To:
perfectly but Carries on running the IF without asking me the Second question. i've tried putting it in else if. but it does not like it either
Please help as im still learning.
PHP:
// Tester.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <stdio.h>   /* required for file operations */
#include <dos.h>  /* for delay */
#include <cstdlib>
//Variables & Pointers
//Vars
char FileNamePath[256] = "test.txt";
char FileNamePathCopy[256] = "test2.txt";
enum {MAX_LEN = 100};
//Pointers
FILE     *OPENFILE, *COPYFILE;            /* declare the file pointer */
//Functions Are Crazy
void LineReadWrite(FILE *fin, FILE *fout)
char buff[MAX_LEN];
while(fgets(buff, MAX_LEN, fin) !=NULL)
        fputs(buff, fout);
        printf("%s",buff);
int _tmain(int argc, _TCHAR* argv[])
    printf("Please Enter The Full Path To Your File You Want To Copy To:\n");
    scanf_s("%c",FileNamePathCopy);
    printf("Please Enter The Full Path To Your File\n");
    scanf_s("%c",FileNamePath);
    if((COPYFILE = fopen(FileNamePathCopy,"w")) == NULL) //should open file
        printf("Cannot Find Your File: %s.\n Please Try Again",FileNamePathCopy); //cannot find file
    else if
        ((OPENFILE=fopen (FileNamePath, "r+"))==NULL)
            printf("Cannot Find Your File: %s.\n Please Try Again",FileNamePath);
    else
        LineReadWrite(OPENFILE,COPYFILE);
        if(fclose(OPENFILE)==0)
            printf("Closed the %s File Sucessfully\n", FileNamePath);
        if(fclose(COPYFILE)==0)
            printf("Closed the %s File Sucessfully\n", FileNamePathCopy);
    system("pause");
    return 0;
this not uni/school work
this is just be indepentanly learning c & wanted somthing half fun to work on. (calculator etc is boring)
i fixed the problem. i know have a dfferent problem. i have a function that should search for a keyword in a text file however when i complile
the error "function does not take 0 arguments" (this is search();
could you please tell me why this is?
the rest of the code works fine & displays. (if you remove search(); for compliing
here is the full code
PHP:
#include "stdafx.h"
#include <string.h>
#include <cstdlib> //Required for System Calls, (System Pause)
//Pointers
FILE * OPENFILE; /* declare the file pointer */
//prototypes
char Search(char SearchText);
//Vars
char FileNamePath[256];
char SearchText[256];
char Text [2000];
char Buffer[512];
//Functions
void ReadTextFile(FILE *READTEXT)
//fgets( Text, 200, OPENFILE );
//printf( "%s", Text);
while(fgets(Text, 2000, OPENFILE) != NULL)
/* get a line, up to 2000 chars from fr. done if NULL */
printf("%s",Text);
/* convert the string to a long int */
void Search();
//search the text inside the temp.txt
printf("search");
scanf("%S",SearchText);
while(fgets(Buffer, 512, OPENFILE) != NULL)
printf("while msg\n");
if((strstr(Buffer, SearchText)) != NULL)
printf("msg is discarded msg\n");
printf("inside of while\n");
printf("Please enter an input filename (use path if needed) :\n");
scanf("%s",FileNamePath);
if((OPENFILE = fopen(FileNamePath,"rt")) == NULL) //should open file
printf("Cannot Find Your Copy File: %s.\n Please Try Again",FileNamePath); //cannot find file
else
printf("Opening %s file successful\n",FileNamePath);
ReadTextFile (OPENFILE);
Search();
printf(" Processing here ");
system("pause");
return 0;
Visual Studio 2010 (Professional Edition) at Work (lunch breaks)
Visual Studio 2010 (Express Edition) at Home.
From what I can see, you have a few problems with your Search function. The first of these is that your types are mismatched; you have a prototype which declares the function of type char, taking one argument also of type char:
Code:
//prototypes
But here where you declare the function, you're trying to declare it as void with no argument.
Code:
void Search();
This is also terminated by a semi-colon, meaning that it is attempting to declare another function prototype rather than the full function body for the earlier Search of type char. When using function prototypes, the prototype and function declarations must match.
