Help With Camera Choice
12 Mar 2008
Complete n00b here looking for first camera advice.
My requirements or description of what I want are probably going to sound very basic to some of you guys but I'm looking for a camera that will take nice stills but also allow me to produce videos good enough for Youtube.
Budget probably in the £200-400 range. Is that enough info?
Cheers.
Sounds like your just after a decent qualty point and shoot. Heres a few good new ones for you. Any of them will easily do what you want, you could spend less no doubt.
  • Sony Cyber-Shot DSC-HX9V
  • Nikon Coolpix S9100
  • Canon Powershot SX230 HS
  • Panasonic Lumix TZ20
The D3100 is a DSLR. Great if that's what your after. Depends what you are after. SLRs are great if you don't mind putting in a bit of effort in getting the most out of them. If your interested in that and want to get ion photography as a hobby then it's worth a look. If you just want to switch it on, take nice snaps, and not faff with settings then go for a point and shoot.
If he wants to get into photography and really have it as a hobby he could use the D3100 in auto mode until learning how to use the camera properly. Its an option, but its hard to say either way without knowing exactly why he wants a camera.
Certainly a hobby is part of it. I spend a lot of time walking and most of that time wishing I had a camera.
I'm also interested in the science and art of what makes a good picture.
I guess as a beginner I'll find out what I want specifically as I go along and get a feel for things.
Defo go into a shop and have a go on a nikon D3100 then mate as it would suit your needs pretty much perfectly.
fuji HS10 is a nice bridge camera to get you going before you move on to Dslr camera and a lot cheaper. as if you find you don't like it then you haven't just spend £450-£1000 on a dslr camera.
