- 12 May 2010
- West Bromwich
I'm going back into air cooling after having a loop in a Phanteks Enthoo Primo. I've still got the Primo but I'm finding GPU temps getting very hot under load (2080Ti)
Need advice on what case to purchase that can support a 360mm AIO (roof mounted) but will also give good airflow for the 2080Ti from front Corsair Ql120 RGB fans
- 011 Dynamic doesn't seem to support front intake fans ?
- Fractal Meshify doesn't seem to support AIO's in the roof.
- Lancool 2 doesn't appear to support 360mm roof radiator and allow for a rear exhaust at the same time (or looks very tight if it does)
- 5000D airflow?
If anyone has any suggestions it would help. Thanks.
- 5000D airflow?
