hey all iv been using a cooler master HAF-X for about 4 years now..the case is old and problems with the usb ports on the front seem to of become faulty over time plus it seems to be fairly uncompatible with some of my components (witch are allso due for a possibleupgrade) iv had to take the main duct off the side panel fan just so i can fit the side panel on the case beacuse of the 980tis sticking out.i think an upgrade is in order but for my current components i dont no what would be best if i should go for another fulltower or somthing els...iv had a few looks around but i really dont no what would be the best option for me..my components
sabertoothz77
corsairH100(needs upgrade)
corsairHX1000(possible upgrade)
sli 980tis (top inno3d hybrid black bottom evga classifed)
3 harddrives. one is an ssd.
some of the cases i had a look at
https://www.overclockers.co.uk/cors...-cube-case-black-cc-9011030-ww-ca-143-cs.html
https://www.overclockers.co.uk/cors...ase-black-window-cc-9011079-ww-ca-213-cs.html
https://www.overclockers.co.uk/cors...tower-case-black-cc-9011073-ww-ca-205-cs.html
https://www.overclockers.co.uk/phanteks-enthoo-evolv-atx-mid-tower-case-gun-metal-ca-030-pt.html
anyone can give me some help would be great.
			sabertoothz77
