- 27 Jan 2003
- Chesterfield, UK
Hi Again,
Sorry for all the questions but what case do you recommend for the most options with regard to fitting WC gear? I'm looking to fit a 120.2 Rad minimum. Looking at the Apex seems a good deal for the Cooling performance you get. Want to try and keep modding to a minimum but the case needs to look good and last.
I like the Lian V1000+ but things look tight and there appears to be a bit of modding work. Super looking case.
Like the look of the Stacker 830 but not sure where you would mount a rad inside. Again looks stunning.
The TJ07 looks ideal because you can drop a 120.3 in the bottom without any mods. The thing looks huge and expensive.
Anything else I should look at for WC cases with Minimum modding?
Still temped to go down the PC3-725 and just accept that it will have a lower cooling capicity but then I think realistically how much difference will I see between a 725 and Apex cooling a X2 4440 and say a X1900. Dilema, Dilema.
Sorry again for all the questions
