- 2 Aug 2006
- Liverpool
not an option as with being disabled, some days I stay in bed so it needs to be movable and compact
Sorry to read that, and noted.not an option as with being disabled, some days I stay in bed so it needs to be movable and compact
Thoughts?its available without a window
From description and pics i would have thought so - Clickycan I setup the aio and fans the same way
Oddly enough that's the bit i'm looking at - it's its one draw back.would 2cm gap be ok for the side
I have my case flush to the inside of my desk - i would have thought 2cm would be enough (but you would be better able to asses this).I meant 2cm against the desk side
You could buy a solid panel for the black red version?the pc should be very steady, I just wish the windowless version was available in black/red
I would have thought you would be able to - you can with most other quality case suppliers.are the panels available separately
1 last question would it be worthwhile moving the bottom fan to the front and removing the odd
CPU Intel Core i7-7700K
CPU Cooler Be Quiet.Silent Loop 280
RAM Team Group Dark Pro 16GB 3000MHz
GPU Gigabyte GeForce GTX 1080 Xtreme Premier Pack
SSD1 Samsung 960 Evo Polaris 500GB
SSD2 Samsung 960 Evo Polaris 500GB
SSD3 Samsung 850 Pro 1TB
PSU Super Flower Leadex Platinum 650W
Blu-Ray Drive Asus DRW-24D5MT
Top: aio rad
front: 2x 140mm
Bottom: 1x 140mm
I just don't want temps higher than they currently are, I think temps are very good at the moment, gpu idles around 30-32c and around 50-60c load, cpu idles around 30-35c and around 60c load
Ah, I assumed it was already.I just thought it would lower temps even further, I'm going to turn the PSU upside down so the fan is facing down
