- 2 Aug 2006
- Liverpool
I don't have a rear fan, just top front and bottom, front and bottom are intakes
Gotcha.I don't have a rear fan, just top front and bottom, front and bottom are intakes
it's filtered don't know its position i think its as far to the right as can go
).Then, personally, I would just swap around the PSU (as you've planned) and observe the temps and perhaps make a decision once you've monitored how this affects the airflow/temps.I'm unable to change config myself so rely on my nephew to do it when he's available, that's why I try to find out before he does it
No problem.ok good advice thanks
Hehe - that does present a bit of an issue.I'd be happy to post when done, only problem is that my psu is silent
Perhaps I'll buy the Super Flower Platinum instead of my planned BeQuiet - excellent reviews across the NET.yes and I've only ever heard the other fans and not that
Yes, i remember - sorry to read things have not got any easier for you.cooling is more important, I'm disabled and suffer with back ache and am bed bound some days, my pc is on that desk and gets moved over to my bed when needed, so anything lighter should make it easier to move the desk
The 280 rad may limit your choices - but will take a look later tonight.I've decided silent isn't important anymore and it's 280 aio, which I'd prefer top mounted if possible
