So the stereo in the Saab isn't very good, I've got a Clarion VX401 head unit on order but I'm anticipating needing to replace the speakers to get some decent quality out of it
The problem is, the setup is a bit...odd. The head unit feeds an amp in the boot which is connected to 7 speakers. 3 mid/tweeters in the dash top (1 in the middle), 2 subs in the front doors and a pair of mid/tweeters in the parcel shelf. The adaptors I've sourced for the head unit take care of connecting it to the factory amp.
I can think of a few ideas
- Replace the left and right dash speakers with something like http://www.caraudio4less.co.uk/boston-acoustics-s35-coaxial-speaker-system-p-1998.html - thats a common upgrade and apparently very helpful
- The door bass drivers arent great and the door panels vibrate at louder volumes. So I could either buy some component sets and scrap the x-over and tweeter, just install the midbass driver. Or I could buy some proper 6.5" shallow fit subs and dynamat the door.
- The rear shelf has 2 small (3.5" again I believe) full range speakers but also cutouts for 6x9s. I could skip/disconnect the front door speakers and put some decent 6x9s in place of the smaller drivers
These would all retain the factory amp, I could bypass it (or replace it with a "normal" amp and put a set of components in the front, replacing the full range drivers in the dash top. Then a 6x9 subwoofer in the rear shelf... a more traditional setup but probably more hassle.
Any ideas what would be best?
