Hi,
I'm interested to build a new computer. This time it should have a small foot-print. Interested to use Silverstone Sugo SG05B Mini-ITX Case.
https://www.overclockers.co.uk/showproduct.php?prodid=CA-063-SV
I would like to use the AMD Phenom II X3 Tri Core 710 2.6GHz, or the 720 (not sure what makes more sense, only 10£ difference).
Mt big problem, which Motherboard, as the case does not take standart ATX boards.
Will by example the Asus M3A78-EM AMD 780G work
http://www.overclockers.co.uk/showproduct.php?prodid=MB-316-AS&groupid=701&catid=5&subcat=807
or which mainboard would you suggest ?.
This is not a 'gaming' / overclocking machine.
Thanks for your help
Frank
Frank
