Help with Compatible Memory Upgrade for Dell XPS 420
13 Jul 2005
Can someone please help me, im wanting to upgrade the memory from 4gb to 8gb on my sons Dell XPS420 computer, i know its DDR2 but the rest of the info goes over my head, would really appreciate some advice
thanks
Looking at the specs, your board should have 4 ram slots, you could add anther 2 x 2 or remove the current ram and purchase 2 x 4gb (assuming the board can take this) your looking at £50 ~ for new ram.
If you have ability to, have a look on the MM.
Ooh - good point!
Op stick your tag number in the Dell support website and it may give you a low down on your system and perhaps BIOS updated which may allow for extra memory.
