help with connecting HD audio
8 Dec 2006
Cardiff
Hi all just wondering if theres anyone that can help me just built my new system using the gigabyte GA-MA790XT-UD4P and a HAF 932 case which comes with both AC97 and HD connector, my OS is vista 64 problem I have is I cant get the front panel headphones or mic to work I have the HD connector plugged into the F_audio and had a look at the realtek audio mangaer but nothing so any help would be great
Thanks
try to look at audio driver configuration (Realtek HA Audio Manager) and un-check "Disable
front panel jack detection" inside "Connector Settings" dialog box. as this option is active for AC'97 front panel, while you have HD connected
